Api session event editor excelsheet set matrix
Revision as of 07:35, 22 September 2026 by Frank@tygron.nl (talk | contribs) (Created page with "API Endpoint: api/session/event/editorexcelsheet/set_matrix/ Description: Set existing Excel Sheet based on matrix (rows and columns) containing the values and formulas for each cell and a second with optional labels. {|class=wikitable !Index !Importance !Type !Description !Values |- | 0 | REQUIRED | (Integer number) | Name | |- | 1 | REQUIRED | (Object or multiple values in array [a, b, c]) | Matrix containing content (numeric value, text of formula starting with...")
0 REQUIRED (Integer number) Name
1 REQUIRED (Object or multiple values in array [a, b, c]) Matrix containing content (numeric value, text of formula starting with =) for each cell.
2 REQUIRED (String or multiple values in array ["a", "b", "c"] or matrix [["a", "b"], ["c", "d"], ["e", "f"]]) Matrix containing labels for each cell, may be empty.
3 REQUIRED (String) Uploader Name
200 Excel ID
curl 'https://engine.tygron.com/api/session/event/editorexcelsheet/set_matrix/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '[ 1, [ 1, "TEXT" ], [ "A1", "B1" ], "Uploader Name" ]'
Curl example multi item POST
curl 'https://engine.tygron.com/api/session/event/editorexcelsheet/set_matrix/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '[ 1, [ [ 1, "TEXT" ], [ 3, "TEXT" ], [ 5, "TEXT" ] ], [ [ "A1", "B1" ], [ "A2", "B2" ], [ "A3", "B3" ] ], "Uploader Name" ]'
JavaScript example POST
 body: '[ 1, [ 1, "TEXT" ], [ "A1", "B1" ], "Uploader Name" ]'
fetch("https://engine.tygron.com/api/session/event/editorexcelsheet/set_matrix/", options)
