Api session event editor excelsheet add matrix
API Endpoint: api/session/event/editorexcelsheet/add_matrix/
Description: Add new Excel Sheet based on matrix (rows and columns) containing the values and formulas for each cell and a second with optional labels.
| 0 | REQUIRED | (String) | Name | |
| 1 | REQUIRED | (Object or multiple values in array [a, b, c]) | Matrix containing content (numeric value, text of formula starting with =) for each cell. | |
| 2 | REQUIRED | (String or multiple values in array ["a", "b", "c"] or matrix [["a", "b"], ["c", "d"], ["e", "f"]]) | Matrix containing labels for each cell, may be empty. | |
| 3 | REQUIRED | (String) | Uploader Name |
| 200 | Integer (Excel ID) |
curl 'https://engine.tygron.com/api/session/event/editorexcelsheet/add_matrix/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '[ "Name", [ 1, "TEXT" ], [ "A1", "B1" ], "Uploader Name" ]'Curl example multi item POST
curl 'https://engine.tygron.com/api/session/event/editorexcelsheet/add_matrix/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '[ "Name", [ [ 1, "TEXT" ], [ 3, "TEXT" ], [ 5, "TEXT" ] ], [ [ "A1", "B1" ], [ "A2", "B2" ], [ "A3", "B3" ] ], "Uploader Name" ]'JavaScript example POST
body: '[ "Name", [ 1, "TEXT" ], [ "A1", "B1" ], "Uploader Name" ]'
fetch("https://engine.tygron.com/api/session/event/editorexcelsheet/add_matrix/", options)
