AI Chat tutorial
Prerequisites
- This tutorial will take approximately ~30 minutes.
- This tutorial can be followed with any project but is designed in the Demo Dxf Import project.
Preparations
- Start the Demo Dxf Import project.
Introduction AI Agents
In the Editor you can interact with several predefined AI Agents via Chat Channels. This tutorial will give you some basic examples of how to interact with them, displaying all functionality. Note that with AI correct answers are not guaranteed!
Wiki Assistant
This agent can only help you with basic functionality of the Tygron Platform. To open it in the Editor go to:
In the following chat box type this questions below and click on the "Send" button:
What is Heat Stress?
How does the PET formula work?
Can you give a link to the WIKI with a Tutorial?
Note that blue hyperlink can be clicked an will open a browser with the relevant WIKI page. Feel free to ask some additional questions.
Next is the Interface explainer:
Go to
- Select the "Noise Impact Traffic" Overlay in the left side panel.
- Select the "Photograph" button just above the "Send" button.
- This will automatically ask the AI Agent to explain what you are seeing in the interface.
- Feel free to ask some additional questions or take more screenshots.
Item Assistant
- Close the previous chat panel.
- Now select the "Ask AI" in the right side panel of your "Noise Impact Traffic" Overlay (ignore the pulldown options).
- This will open a new Chat window named "Noise Impact Traffic" which is context aware to the selected Overlay.
- You can ask several question in relation to this Overlay:
What your Overlay ID?
Rename to "test overlay"
Disable overlay
Again feel free to ask some additional questions.
Project Coder
Sofar you have been working with the basic WIKI and Items assistants. To do more advanced things like TQL or coding you need the advanced "Project Coder" agent. Go to
- This opens the slower but more advanced model needed for coding.
- Ask it the following questions:
Give me a TQL query for the average value of overlay 15?
Adjust the query to calculate the value per neighborhood
Run the query
Plot this as a bar chart in a Panel
Check the result by opening the newly created panel in the "Panels" menu.
You can also ask the Project Coder to adjust the overlay further:
Set the background noise to 50 for overlay 15
Explain what I am seeing
What is the API endpoint for this overlay?
Drag & Drop
The Agents also support dropping files and using it in the chat.
- Select the wiki page you are currently reading by dragging the URL (in Firefox this can be done via the lock icon next to the URL address bar) and dropping the URL in the chat input field.
- When succesfull "TEXT" will appear next to the field.
- Ask the AI to:
Summarize
- This can also be done for regular PDF or image files or a GeoJSON endpoint from another project.
Custom Agents (Advanced)
You have sofar been using predefined Tygron Agents. It is also possible to create your own agents with specific instructions.
- Go back to the chat panel, select the Wiki Assistant and click on the "Duplicate" button in the lower left corner.
- This will open channel for "Wiki Assistant (2)".
- Click on "Show Settings" to get access to the Agent's channel settings.
- Here you can edit for example the AI "instructions" and provide it with additional instructions on how do things.
- These instructions can also be shared via the GeoShare with fellow team members working in other projects.
- Hovering of the Tools with your mouse explains the tools functionality.
- You can also adjust other attributes, like for example the temperature controls how creative the agents can be (higher is more creative and more hallucinations, lower is stricter). See Chat Channel for more information on each attribute.
Tutorial completed
Congratulations. You have now completed this tutorial. In it, you have learned how to use the Chat functionality to interact with AI Agents..
