Api session event participant event bundle apply server events
Revision as of 10:00, 13 July 2026 by Frank@tygron.nl (talk | contribs)
API Endpoint: api/session/event/participant/event_bundle_apply_server_events/
Description: Apply a bundle of events on the server side for a particular Stakeholder.
0 REQUIRED (STAKEHOLDER Integer ID) Stakeholder ID
1 REQUIRED (EVENT_BUNDLE Integer ID) Event Bundle ID
200 Integer (Action Log ID)
curl 'https://engine.tygron.com/api/session/event/participant/event_bundle_apply_server_events/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '[ 1, 1 ]'
JavaScript example POST
 body: '[ 1, 1 ]'
fetch("https://engine.tygron.com/api/session/event/participant/event_bundle_apply_server_events/", options)
