Api session event participant building plan demolish polygon
Revision as of 10:00, 13 July 2026 by Frank@tygron.nl (talk | contribs)
API Endpoint: api/session/event/participant/building_plan_demolish_polygon/
Description: Plan the demolition of Buildings in the given Polygon in the MAQUETTE map.
0 REQUIRED (STAKEHOLDER Integer ID) Stakeholder ID
1 REQUIRED (MultiPolygon with crs: EPSG:3857) MultiPolygon describing the demolition Area
2 REQUIRED (Enumeration) Ground type: SURFACE or UNDERGROUND BRIDGE, SURFACE or UNDERGROUND
200 Integer (Action Log ID)
curl 'https://engine.tygron.com/api/session/event/participant/building_plan_demolish_polygon/?crs=3857' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '
[ 1, {
 "type" : "MultiPolygon",
 "coordinates" : [ [ [ [ 658636.762, 6799451.896 ], [ 658636.762, 6799461.896 ], [ 658646.762, 6799461.896 ], [ 658646.762, 6799451.896 ], [ 658636.762, 6799451.896 ] ] ] ]
}, "BRIDGE" ]
JavaScript example POST
 body: '[ 1, { "type" : "MultiPolygon", "coordinates" : [ [ [ [ 658636.762, 6799451.896 ], [ 658636.762, 6799461.896 ], [ 658646.762, 6799461.896 ], [ 658646.762, 6799451.896 ], [ 658636.762, 6799451.896 ] ] ] ]}, "BRIDGE" ]'
fetch("https://engine.tygron.com/api/session/event/participant/building_plan_demolish_polygon/?crs=3857", options)
