Api session event logic set net setting boolean
API Endpoint: api/session/event/logic/set_net_setting_boolean/
Description: Set a boolean value for the specified Net Setting.
| 0 | REQUIRED | (Type or multiple values in array [a, b, c]) | Net Setting Type | |
| 1 | REQUIRED | (Boolean or multiple boolean values in array [true, false, true]) | True or false |
| 204 | No Content |
curl 'https://engine.tygron.com/api/session/event/logic/set_net_setting_boolean/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '[ "CLUSTER_FRACTION_CONNECTED", true ]'Curl example multi item POST
curl 'https://engine.tygron.com/api/session/event/logic/set_net_setting_boolean/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '[ [ "CLUSTER_FRACTION_CONNECTED", "REQUIRE_UTILITY_CORPORATION_APPROVAL", "CLUSTER_MODELS_ENABLED" ], [ true, false, true ] ]'JavaScript example POST
body: '[ "CLUSTER_FRACTION_CONNECTED", true ]'
fetch("https://engine.tygron.com/api/session/event/logic/set_net_setting_boolean/", options)
