Api session event logic global set value
Revision as of 10:00, 13 July 2026 by Frank@tygron.nl (talk | contribs)
API Endpoint: api/session/event/logic/global_set_value/
Description: Set the Global variable to the specified numeric value.
0 REQUIRED (GLOBAL Integer ID or multiple integer values in array [1, 2, 3]) Global ID
1 REQUIRED (Floating point number or multiple values in array [1.0, 2.0, 3.0]) Value
204 No Content
curl 'https://engine.tygron.com/api/session/event/logic/global_set_value/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '[ 1, 1.0 ]'
Curl example multi item POST
curl 'https://engine.tygron.com/api/session/event/logic/global_set_value/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '[ [ 1, 2, 3 ], [ 1.0, 2.0, 3.0 ] ]'
JavaScript example POST
 body: '[ 1, 1.0 ]'
fetch("https://engine.tygron.com/api/session/event/logic/global_set_value/", options)
