Api session event editor weather set flood overlay
API Endpoint: api/session/event/editorweather/set_flood_overlay/
Description: Set a specific visualization Overlay for a specified Weather.
| 0 | REQUIRED | (WEATHER Integer ID or multiple integer values in array [1, 2, 3]) | Weather ID | |
| 1 | REQUIRED | (OVERLAY Integer ID or multiple integer values in array [1, 2, 3]) | Visualization Overlay ID |
| 204 | No Content |
curl 'https://engine.tygron.com/api/session/event/editorweather/set_flood_overlay/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '[ 1, 1 ]'Curl example multi item POST
curl 'https://engine.tygron.com/api/session/event/editorweather/set_flood_overlay/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '[ [ 1, 2, 3 ], [ 1, 2, 3 ] ]'JavaScript example POST
body: '[ 1, 1 ]'
fetch("https://engine.tygron.com/api/session/event/editorweather/set_flood_overlay/", options)
