Api session event editor weather duplicate
Revision as of 10:00, 13 July 2026 by Frank@tygron.nl (talk | contribs)
API Endpoint: api/session/event/editorweather/duplicate/
Description: Duplicate the specified Weathers as independent copies.
0 REQUIRED (WEATHER Integer ID or multiple integer values in array [1, 2, 3]) Weather IDs
200 Integer[] (Integer array)
curl 'https://engine.tygron.com/api/session/event/editorweather/duplicate/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '1'
Curl example multi item POST
curl 'https://engine.tygron.com/api/session/event/editorweather/duplicate/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '[ 1, 2, 3 ]'
JavaScript example POST
 body: '1'
fetch("https://engine.tygron.com/api/session/event/editorweather/duplicate/", options)
