Api session event editor scenario set active
Revision as of 09:59, 13 July 2026 by Frank@tygron.nl (talk | contribs)
API Endpoint: api/session/event/editorscenario/set_active/
Description: Activate Scenario. If a test run is active, the Scenario can restart it.
0 REQUIRED (SCENARIO Integer ID) Scenario ID
204 No Content
curl 'https://engine.tygron.com/api/session/event/editorscenario/set_active/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '1'
JavaScript example POST
 body: '1'
fetch("https://engine.tygron.com/api/session/event/editorscenario/set_active/", options)
