Api session event editor parametric remove attribute
API Endpoint: api/session/event/editorparametric/remove_attribute/
Description: Remove numeric Attribute from Parametric
| 0 | REQUIRED | (PARAMETRIC_DESIGN Integer ID or multiple integer values in array [1, 2, 3]) | Parametric Design | |
| 1 | REQUIRED | (String or multiple values in array ["a", "b", "c"]) | Attribute Name |
| 204 | No Content |
curl 'https://engine.tygron.com/api/session/event/editorparametric/remove_attribute/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '[ 1, "Attribute Name 1" ]'Curl example multi item POST
curl 'https://engine.tygron.com/api/session/event/editorparametric/remove_attribute/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '[ [ 1, 2, 3 ], [ "Attribute Name 1", "Attribute Name 2", "Attribute Name 3" ] ]'JavaScript example POST
body: '[ 1, "Attribute Name 1" ]'
fetch("https://engine.tygron.com/api/session/event/editorparametric/remove_attribute/", options)
