Api session event editor overlay set parent
Revision as of 09:59, 13 July 2026 by Frank@tygron.nl (talk | contribs)
API Endpoint: api/session/event/editoroverlay/set_parent/
Description: Set a parent Overlay for a specified Overlay, making it a subselectable child. An Overlay with a parent cannot be assigned as a parent to another Overlay.
0 REQUIRED (OVERLAY Integer ID) Overlay ID
1 REQUIRED (Integer number) Overlay ID of parent (Overlays without a parent should have their parent Overlay ID set to -1)
204 No Content
curl 'https://engine.tygron.com/api/session/event/editoroverlay/set_parent/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '[ 1, 1 ]'
JavaScript example POST
 body: '[ 1, 1 ]'
fetch("https://engine.tygron.com/api/session/event/editoroverlay/set_parent/", options)
