How to add and remove an action menu
Revision as of 07:25, 9 July 2026 by Maxim@tygron.com (talk | contribs)
Editor → Future Design (Ribbon tab) → Actions (Ribbon bar)
The left panel in the editor, when editing the actions.
To add an action to a stakeholder, you must first create an menu to house the action. A menu without actions will appear as empty to the user.
How to add an action menu:
  1. Select "Stakeholders" in the ribbon header.
  2. Select "Actions" in the ribbon bar.
  3. Select "Add" in the left panel.
How to remove an action menu:
  3. Select the menu you wish to remove.
  4. Select "Remove" in the left panel.
Order
The buttons with which to alter the "order" of the menus.
The menu order defines the order in which the menus are being presented to the user. You can change the order by selecting a menu and pressing "Up" and "Down".
