How to add and remove Event Bundles
Revision as of 12:05, 7 July 2026 by Frank@tygron.nl (talk | contribs)
Editor → Future Design (Ribbon tab) → Event Bundles (Ribbon bar)
The Left Panel allows you to add, remove, and select event bundles.
Empty event bundles can be created and populated later; until they contain events, they have no effect.
How to add an event bundle:
  1. In the ribbon header, select "Future Design".
  2. In the ribbon bar, select "Event Bundles".
  3. In the left panel, select "Add".
How to duplicate an event bundle:
  3. In the left panel, select the event bundle you wish to duplicate.
  4. In the left panel, select "Duplicate".
How to remove an event bundle:
  3. In the left panel, select the event bundle you wish to remove.
  4. In the left panel, select "Remove".
