Training
Tygron Academy
For an overview of the training possibilities offered by Tygron please check our website: https://www.tygron.com/nl/tygron-academy/
Quickstart training Tygron Platform
Do you want to get started quickly on your own projects using the Tygron Platform? Then sign up with your colleagues on a Quickstart training.
Details Quickstart training
Program
In a start-up meeting we discuss your learning objectives and set the details of the program for the quickstart training day. Possible subjects, depending on your learning objectives, are:
  • How to build a 3D dynamic model?
  • How to add and export data?
  • How calculation models work in the Tygron Platform, including how to adjust or add your own.
After the training, you are able to apply the Tygron Platform for your own projects. You will have documentation and exercises available to you to make an effective start. You will gain insight into the Tygron Platform's possibilities and identify areas for further learning.
Target audience: max. 6 colleagues who are planning to work with projects in the Tygron Platform. There is no specific foreknowledge required, but attendance of at least one trainee with knowledge and experience in GIS is preferable.
Duration: 1 start-up meeting and 1 training day.
Licence
In order to be able to join the training, you need a licence to the Tygron Platform.
Follow-up
After the Quickstart you will have a full understanding of the possibilities of the Tygron Platform. Tygron has a better understanding of your goals and how you wish to use the Tygron Platform. Together we can discuss the follow-up. You can likely continue independently after the Quickstart. The Tygron Platform is well documented and can be used intuitively. It is also possible that more training or 'Q&A/work sessions' are desired.
Contact
For more information or to sign up for a training session, please contact Tygron support: Template:Email.
