How to remove Attributes from multiple Items
Revision as of 11:42, 7 July 2026 by Frank@tygron.nl (talk | contribs)
To accommodate the removal of an Attribute for a large set of components at once, the Remove Attribute panel was added.
This panel allows users to remove an attribute from multiple items at once. Additionally, users can filter out only specific items based on the configured filter.
How to open the panel
Open the Remove Attributes panel via the editor ribbon bar, then hover over a component with attributes (e.g., Areas).
Select an attribute
Select an attribute from the list and click on the select button. Alternatively double click on the attribute.
Filters
To improve the usability of this panel, generic filters have been added. Some components also have additional filters. For example, Buildings have an additional Category filter.
Option 1: No filter
Option 1: No filter, so all components of this type are considered.
Option 2: Filter on attribute
Option 2: A filter requiring the component to have the specified attribute.
Option 3: Filter on attribute and value
Option 3: A filter requiring the component to have the specified attribute and its value to be in the specified range.
