Api session items parametricdesigns
API Endpoint: /api/session/items/parametricdesigns/
Edit items with events described at Api session event editor parametric.
Default Query:
https://engine.tygron.com/api/session/items/parametricdesigns/?f=JSON&token=API_TOKEN
Example Response:
Limit Queries
version=100:
https://engine.tygron.com/api/session/items/parametricdesigns/?version=100&token=API_TOKEN
Show Queries
Formats
HTML:
https://engine.tygron.com/api/session/items/parametricdesigns/?f=HTML&token=API_TOKEN
JSON:
CSV:
https://engine.tygron.com/api/session/items/parametricdesigns/?f=CSV&token=API_TOKEN
SSV:
https://engine.tygron.com/api/session/items/parametricdesigns/?f=SSV&token=API_TOKEN
SMILE:
https://engine.tygron.com/api/session/items/parametricdesigns/?f=SMILE&token=API_TOKEN
ZIPJSON:
https://engine.tygron.com/api/session/items/parametricdesigns/?f=ZIPJSON&token=API_TOKEN
ZIPSMILE:
https://engine.tygron.com/api/session/items/parametricdesigns/?f=ZIPSMILE&token=API_TOKEN
Api Model Alignment
API Enumeration description of Alignment
Name Description
ROAD
SPACED
Api Model GeometryCollection
API Model description of GeometryCollection
Name Type Description
Api Model MultiPolygon
API Model description of MultiPolygon
type String MultiPolygon
coordinates double[][][][] array of Polygons; Polygon is array of outer and optional inner rings; rings is array of coordinates; coordinates is array of [x,y,(optional) z]
Api Model ParametricDesign
API Model description of ParametricDesign
alignment Alignment
attributes Map<String,double[]>
center Point Point
gardenID int Function ID
id int
maquetteOverride Map<String,double[]>
name String
parkingID int Function ID
plotDesigns PlotDesign[] PlotDesign[]
polygons MultiPolygon MultiPolygon
publicGreenID int Function ID
roadID int Function ID
sidewalkID int Function ID
sourceIDs int[] Sources ID
version int
waterID int Terrain Type ID
Api Model PlotDesign
API Model description of PlotDesign
functionID int Function ID
id int
multiPolygon MultiPolygon MultiPolygon
Api Model Point
API Model description of Point
type String Point
coordinates double[] x, y, (optional) z
