List of Combo Overlay examples
Attribute
Solid Buildings
The attribute SOLID generally has a value of 0 or 1. It can therefore be used directly in a Combo Overlay Formula.
  • Set Combo Maplink to BUILDINGS
  • Set Key A to SOLID
  • Set Formula to:
    @A
Residential Buildings
The unit size category values can be used to identify and rasterize residences, in combination with a GT (Greater than) function with multiple arguments. To setup:
  • Set Combo Rasterization to "Attribute:Specific Layer" (SINGLE_LAYER)
  • Set Combo Maplink to Buildings
  • Set Key A to SOCIAL_UNIT_SIZE_M2
  • Set Key B to NORMAL_UNIT_SIZE_M2
  • Set Key C to LUXE_UNIT_SIZE_M2
  • Set Key D to STUDENT_UNIT_SIZE_M2
  • Set Key E to SENIOR_UNIT_SIZE_M2
  • Set Formula to:
    GT(@A,@B,@C,@D,@E)
Categorized Residential Buildings
The unit size category values can be used to identify and rasterize residence types, in combination with a IF and GT (Greater than) functions with multiple arguments. We will categorize the residential buildings as followed: SOCIAL (1) , NORMAL (2), LUXE (3), SENIOR (4), STUDENT (5) and everything else 0.
To setup:
  • Set Key D to SENIOR_UNIT_SIZE_M2
  • Set Key E to STUDENT_UNIT_SIZE_M2
  • Set Formula to:
    IF(GT(@A,0),1,IF(GT(@B,0),2,IF(GT(@C,0),3, IF(GT(@D,0), 4, IF(GT(@E,0),5,0))))
Rasterization
Minimum infiltration among layers
An example on how the combo overlay can obtain rasterized data from multiple data layers (MapLinks); Terrains, Buildings, Neighborhoods, Areas and Zones.
Timeframes
Minimum value among timeframes
An example on how the Combo Overlay can calculate the minimum value among timeframes of a Prequel Grid Overlay
Maximum value among timeframes
An example on how the Combo Overlay can calculate the maximum value among timeframes of a Prequel Grid Overlay
Average value among timeframes
An example on how the Combo Overlay can calculate the average value among timeframes of a Prequel Grid Overlay, for example a Shadow Overlay:
Mask for each timeframe
An example on how the Combo Overlay can calculate, for each timeframe of an input overlay, whether a grid value is above a specific value. In this example a Heat Stress Overlay with a minimum value of 45 degrees.
Filter each timeframe
An example on how the Combo Overlay can calculate, for each timeframe of an input overlay, only include a grid value when it is above a specific value, and make it NO_DATA otherwise. In this example a Heat Stress Overlay with a minimum value of 45 degrees.
  • Set A prequel (Combo Overlay) to a Grid Overlay, in this example a Heat Stress Overlay.
  • Set Formula to:
    IF(GT(AT, 45), AT, NO_DATA)
Iteration
For initializing a Combo Overlay in a iteration setup, the ITERATION parameter can be used to obtain the active Iteration number.
Colors
Grid input to colors
An example on how a combo overlay can return a complex colorization using a grid input without using a legend. This example expects the value of an input Grid Overlay to be:
  • Negative or NO_DATA in case it has no direction
  • A value between 0 and 360 indicating a direction.
Configure the Combo Overlay as followed:
  • Set Grid A to an input overlay representing a direction in degrees, such as Surface avg direction result type (Water Overlay)
  • Set Formula to:
    IF(OR(LT(AT, 0), EQ(NO_DATA, AT)), NO_DATA, IF(LT(AT, 15), COLOR(255, 0), IF(LT(AT, 45), COLOR(255, 125, 0), IF(LT(AT, 75), COLOR(255, 255, 0), IF(LT(AT, 105), COLOR(125, 255, 0), IF(LT(AT, 135), COLOR(0, 255, 0), IF(LT(AT, 165), COLOR(0, 255, 125), IF(LT(AT, 195), COLOR(0, 255, 255), IF(LT(AT, 225), COLOR(0, 125, 255), IF(LT(AT, 255), COLOR(0, 0, 255), IF(LT(AT, 285), COLOR(125, 0, 255), IF(LT(AT, 315), COLOR(225, 0, 225), IF(LT(AT, 345), COLOR(225, 0, 125), COLOR(255, 0, 0))))))))))))))
Saturate Satellite Imagery
The satellite imagery colors can be saturated using a saturation approximation function. In this example the factor is set to 0.9.
  • Set Grid A to a Satellite Overlay
  • Set Formula to:
    COLOR(
     ADD(MUL(-1, 0.9,
      ADD(MUL(0.2989, RED(A)), MUL(0.587, GREEN(A)), MUL(0.114, BLUE(A)))), MUL(ADD(1, 0.9), RED(A))),
     ADD(MUL(-1, 0.9,
      ADD(MUL(0.2989, RED(A)), MUL(0.587, GREEN(A)), MUL(0.114, BLUE(A)))), MUL(ADD(1, 0.9), GREEN(A))),
     ADD(MUL(-1, 0.9,
      ADD(MUL(0.2989, RED(A)), MUL(0.587, GREEN(A)), MUL(0.114, BLUE(A)))), MUL(ADD(1, 0.9), BLUE(A)))
