Api session event editor source add service
API Endpoint: api/session/event/editorsource/add_service/
Description: Add Service
| 0 | REQUIRED | (Enumeration) | geoformat | BGT_GML, DXF, ESRI_IMAGE, ESRI_JSON, GEOJSON, GEOPACKAGE, GEOTIFF, I3S, OSM, WCS_TIFF, WFS_GML, WFS_JSON or WMS_IMAGE |
| 1 | REQUIRED | (String) | String | |
| 2 | REQUIRED | (String) | String | |
| 3 | REQUIRED | (String) | String |
| 200 | Integer (Integer) |
curl 'https://engine.tygron.com/api/session/event/editorsource/add_service/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '[ "GEOJSON", "Text", "Text", "Text" ]'JavaScript example POST
body: '[ "GEOJSON", "Text", "Text", "Text" ]'
fetch("https://engine.tygron.com/api/session/event/editorsource/add_service/", options)
