Api session items zones
API Endpoint: /api/session/items/zones/
Edit items with events described at Api session event editor zoning.
Default Query:
https://engine.tygron.com/api/session/items/zones/?f=JSON&token=API_TOKENExample Response:
[ ]Limit Queries
version=100:
https://engine.tygron.com/api/session/items/zones/?version=100&token=API_TOKENPseudo-Mercator:
https://engine.tygron.com/api/session/items/zones/?crs=3857&token=API_TOKENDegrees:
https://engine.tygron.com/api/session/items/zones/?crs=4326&token=API_TOKENAmersfoort / RD New:
https://engine.tygron.com/api/session/items/zones/?crs=28992&token=API_TOKENLocal Coordinates:
https://engine.tygron.com/api/session/items/zones/?crs=LOCAL&token=API_TOKENbbox=658636.7618515313,6798649.869141218,659042.7958749933,6799055.882798785:
https://engine.tygron.com/api/session/items/zones/?crs=3857&bbox=658636.7618515313,6798649.869141218,659042.7958749933,6799055.882798785&token=API_TOKENFOO:
https://engine.tygron.com/api/session/items/zones-foo/?crs=3857&token=API_TOKENShow Queries
max version:
https://engine.tygron.com/api/session/items/zones/version/?token=API_TOKENsize:
https://engine.tygron.com/api/session/items/zones/size/?token=API_TOKENFormats
HTML:
https://engine.tygron.com/api/session/items/zones/?f=HTML&token=API_TOKEN&crs=3857JSON:
https://engine.tygron.com/api/session/items/zones/?f=JSON&token=API_TOKEN&crs=3857GEOJSON:
https://engine.tygron.com/api/session/items/zones/?f=GEOJSON&token=API_TOKEN&crs=3857GPKG:
https://engine.tygron.com/api/session/items/zones/?f=GPKG&token=API_TOKEN&crs=3857DXF:
https://engine.tygron.com/api/session/items/zones/?f=DXF&token=API_TOKEN&crs=3857CSV:
https://engine.tygron.com/api/session/items/zones/?f=CSV&token=API_TOKEN&crs=3857SSV:
https://engine.tygron.com/api/session/items/zones/?f=SSV&token=API_TOKEN&crs=3857SMILE:
https://engine.tygron.com/api/session/items/zones/?f=SMILE&token=API_TOKEN&crs=3857ZIPJSON:
https://engine.tygron.com/api/session/items/zones/?f=ZIPJSON&token=API_TOKEN&crs=3857ZIPSMILE:
https://engine.tygron.com/api/session/items/zones/?f=ZIPSMILE&token=API_TOKEN&crs=3857Api Model Category
API Enumeration description of Category
| Name | Description |
| SOCIAL | |
| NORMAL | |
| LUXE | |
| ROAD | |
| PAVED_AREA | |
| EDUCATION | |
| HEALTHCARE | |
| PARK | |
| NATURE | |
| INDUSTRY | |
| OFFICES | |
| OTHER | |
| SENIOR | |
| UNDERGROUND | |
| SHOPPING | |
| AGRICULTURE | |
| LEISURE | |
| STUDENT | |
| GARDEN | |
| INTERSECTION | |
| BRIDGE |
Api Model CategoryZone
API Model description of CategoryZone
| Name | Type | Description |
| allowedCategories | Category[] | Category[] |
| attributes | Map<String,double[]> | |
| center | Point | Point |
| excelID | int | Excel Sheet ID |
| excelUpdated | boolean | |
| id | int | |
| maquetteOverride | Map<String,double[]> | |
| name | String | |
| outline | Outline | |
| parentZoneID | int | Zone ID |
| permitterID | int | Stakeholder ID |
| polygons | MultiPolygon | MultiPolygon |
| sourceIDs | int[] | Sources ID |
| version | int |
Api Model GeometryCollection
API Model description of GeometryCollection
Api Model MultiPolygon
API Model description of MultiPolygon
| type | String | MultiPolygon |
| coordinates | double[][][][] | array of Polygons; Polygon is array of outer and optional inner rings; rings is array of coordinates; coordinates is array of [x,y,(optional) z] |
Api Model Outline
API Enumeration description of Outline
| NONE | |
| SIMPLE | |
| DASHED |
Api Model Point
API Model description of Point
| type | String | Point |
| coordinates | double[] | x, y, (optional) z |
Api Model Zone
API Model description of Zone
| id | int | |
| name | String | |
| version | int |
