Api session event editor netsetting set cluster fraction connected
API Endpoint: api/session/event/editornetsetting/set_cluster_fraction_connected/
Description: Set Cluster Fraction Connected
| 0 | REQUIRED | (Floating point number) | Double |
| 204 | No Content |
curl 'https://engine.tygron.com/api/session/event/editornetsetting/set_cluster_fraction_connected/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '85'Curl example multi item POST
curl 'https://engine.tygron.com/api/session/event/editornetsetting/set_cluster_fraction_connected/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '64'JavaScript example POST
body: '85'
fetch("https://engine.tygron.com/api/session/event/editornetsetting/set_cluster_fraction_connected/", options)
