Api session event editor global set point
Revision as of 13:01, 19 June 2026 by Frank@tygron.nl (talk | contribs)
API Endpoint: api/session/event/editorglobal/set_point/
Description: Set Point
0 REQUIRED (GLOBAL Integer ID) Globals
1 REQUIRED (Point with crs: EPSG:3857) Point
204 No Content
curl 'https://engine.tygron.com/api/session/event/editorglobal/set_point/?crs=3857' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '
[ 1, {
 "type" : "Point",
 "coordinates" : [ 658747.3314126644, 6799369.70776837 ]
Curl example multi item POST
[ 1, {
 "type" : "Point",
 "coordinates" : [ 658704.561412769, 6799444.34606075 ]
JavaScript example POST
 body: '[ 1, { "type" : "Point", "coordinates" : [ 658747.3314126644, 6799369.70776837 ]} ]'
fetch("https://engine.tygron.com/api/session/event/editorglobal/set_point/?crs=3857", options)
