Api session event editor global remove point
Revision as of 13:01, 19 June 2026 by Frank@tygron.nl (talk | contribs)
API Endpoint: api/session/event/editorglobal/remove_point/
Description: Remove Point
0 REQUIRED (GLOBAL Integer ID) Globals
204 No Content
curl 'https://engine.tygron.com/api/session/event/editorglobal/remove_point/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '1'
JavaScript example POST
 body: '1'
fetch("https://engine.tygron.com/api/session/event/editorglobal/remove_point/", options)
