Api session event editor start map creation
Revision as of 13:00, 19 June 2026 by Frank@tygron.nl (talk | contribs)
API Endpoint: api/session/event/editor/start_map_creation/
Description: Set the Project's georeference center Point to the provided coordinates and begin the process of automatically load in available data.
0 REQUIRED (Floating point number) Center Point (Longitude or X coordinate)
1 REQUIRED (Floating point number) Center Point (Latitude or Y coordinate)
2 OPTIONAL (MultiPolygon with crs: EPSG:3857) Optional: Limit data loading to this Polygon
3 OPTIONAL (MultiPolygon with crs: EPSG:3857 or multiple values in array [a, b, c]) Optional: Area of Interest Polygons
204 No Content
curl 'https://engine.tygron.com/api/session/event/editor/start_map_creation/?crs=3857' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '[ 11, 94 ]'
Curl example multi item POST
curl 'https://engine.tygron.com/api/session/event/editor/start_map_creation/?crs=3857' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '[ 20, 75 ]'
JavaScript example POST
 body: '[ 11, 94 ]'
fetch("https://engine.tygron.com/api/session/event/editor/start_map_creation/?crs=3857", options)
