Api session query
API Endpoint: api/session/query/
GET query
Parameters:
Name Location Type Default value
f Query Format JSON
crs Query String EPSG:3857
GET query
Parameters:
query Path String
value Query String 0.0
f Query Format JSON
validate Query boolean false
POST query
Content-Type: application/x-www-form-urlencoded
Parameters:
f Query Format JSON
Examples
curl 'https://engine.tygron.com/api/session/query/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '"TQL Query 1"'
Curl example multi item POST:
curl 'https://engine.tygron.com/api/session/query/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '[ "TQL Query 1", "TQL Query 2", "TQL Query 3" ]'
JavaScript example POST:
 body: '"TQL Query 1"'
fetch("https://engine.tygron.com/api/session/query/", options)
POST query
Parameters:
f Query Format JSON
Examples
GET SELECT_FLOORSIZE_WHERE_CATEGORY_IS_OFFICES_AND_MAP_IS_MAQUETTE
API Endpoint: api/session/query/SELECT_FLOORSIZE_WHERE_CATEGORY_IS_OFFICES_AND_MAP_IS_MAQUETTE
Parameters:
query Path String
f Query Format JSON
Examples
SELECT_FLOORSIZE_WHERE_CATEGORY_IS_OFFICES_AND_MAP_IS_MAQUETTE:
https://engine.tygron.com/api/session/query/SELECT_FLOORSIZE_WHERE_CATEGORY_IS_OFFICES_AND_MAP_IS_MAQUETTE?crs=3857&f=JSON&token=API_TOKEN
GET SELECT_COLOR_WHERE_CATEGORY_IS_UNDERGROUND
API Endpoint: api/session/query/SELECT_COLOR_WHERE_CATEGORY_IS_UNDERGROUND
Parameters:
query Path String
f Query Format JSON
Examples
SELECT_COLOR_WHERE_CATEGORY_IS_UNDERGROUND:
https://engine.tygron.com/api/session/query/SELECT_COLOR_WHERE_CATEGORY_IS_UNDERGROUND?crs=3857&f=JSON&token=API_TOKEN
GET SELECT_FLOORSIZE_WHERE_CATEGORY_IS_GARDEN_AND_MAP_IS_MAQUETTE
API Endpoint: api/session/query/SELECT_FLOORSIZE_WHERE_CATEGORY_IS_GARDEN_AND_MAP_IS_MAQUETTE
Parameters:
query Path String
f Query Format JSON
Examples
SELECT_FLOORSIZE_WHERE_CATEGORY_IS_GARDEN_AND_MAP_IS_MAQUETTE:
https://engine.tygron.com/api/session/query/SELECT_FLOORSIZE_WHERE_CATEGORY_IS_GARDEN_AND_MAP_IS_MAQUETTE?crs=4326&f=JSON&token=API_TOKEN
GET SELECT_COLOR_WHERE_CATEGORY_IS_SHOPPING
API Endpoint: api/session/query/SELECT_COLOR_WHERE_CATEGORY_IS_SHOPPING
Parameters:
query Path String
f Query Format JSON
Examples
SELECT_COLOR_WHERE_CATEGORY_IS_SHOPPING:
https://engine.tygron.com/api/session/query/SELECT_COLOR_WHERE_CATEGORY_IS_SHOPPING?crs=28992&f=JSON&token=API_TOKEN
GET SELECT_NAME_WHERE_CATEGORY_IS_SHOPPING
API Endpoint: api/session/query/SELECT_NAME_WHERE_CATEGORY_IS_SHOPPING
Parameters:
query Path String
f Query Format JSON
Examples
SELECT_NAME_WHERE_CATEGORY_IS_SHOPPING:
https://engine.tygron.com/api/session/query/SELECT_NAME_WHERE_CATEGORY_IS_SHOPPING?crs=LOCAL&f=JSON&token=API_TOKEN
