Api session event logic set net setting boolean
Revision as of 12:24, 17 June 2026 by Frank@tygron.nl (talk | contribs)
API Endpoint: api/session/event/logic/set_net_setting_boolean/
Description: For boolean valued Net Settings (ELECTRICITY_ACTIVE, GAS_ACTIVE, HEAT_ACTIVE, INTERNET_ACTIVE, SEWER_ACTIVE, REQUIRE_UTILITY_CORPORATION_APPROVAL, CLUSTER_MODELS_ENABLED, LOAD_TO_NODE_LINES_ENABLED, FIRST_CONNECT_ACCEPT, RESTRICT_TO_NET_Overlay), set the value to true or false.
0 REQUIRED (Type or multiple values in array [a, b, c]) Net Setting Type
1 REQUIRED (Boolean or multiple boolean values in array [true, false, true]) True or false
204 No Content
curl 'https://engine.tygron.com/api/session/event/logic/set_net_setting_boolean/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '[ "CLUSTER_FRACTION_CONNECTED", true ]'
Curl example multi item POST
curl 'https://engine.tygron.com/api/session/event/logic/set_net_setting_boolean/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '[ [ "CLUSTER_FRACTION_CONNECTED", "REQUIRE_UTILITY_CORPORATION_APPROVAL", "CLUSTER_MODELS_ENABLED" ], [ true, false, true ] ]'
JavaScript example POST
 body: '[ "CLUSTER_FRACTION_CONNECTED", true ]'
fetch("https://engine.tygron.com/api/session/event/logic/set_net_setting_boolean/", options)
