Web token
Revision as of 12:23, 17 June 2026 by Frank@tygron.nl (talk | contribs) (Created page with "API Endpoint: api/session/event/editorstakeholder/reset_web_token/ Description: Reset Web Token {|class=wikitable !Index !Importance !Type !Description !Values |- | 0 | REQUIRED | (STAKEHOLDER Integer ID or multiple integer values in array [1, 2, 3]) | Stakeholders | |} ===Response Codes=== {|class=wikitable !Response Code: !Description |- | 204 | No Content |- | 300-600 | Codes Overview |} ===Example POST=== Curl example POST <syntaxhighlight lang="text" copy>cur...")
0 REQUIRED (STAKEHOLDER Integer ID or multiple integer values in array [1, 2, 3]) Stakeholders
204 No Content
curl 'https://engine.tygron.com/api/session/event/editorstakeholder/reset_web_token/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '1'
Curl example multi item POST
curl 'https://engine.tygron.com/api/session/event/editorstakeholder/reset_web_token/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '[ 1, 2, 3 ]'
JavaScript example POST
 body: '1'
fetch("https://engine.tygron.com/api/session/event/editorstakeholder/reset_web_token/", options)
