Api session event editor scenario set restart testrun
API Endpoint: api/session/event/editorscenario/set_restart_testrun/
Description: When true test run is restarted on Scenario activation. This option will be deprecated in the future and replaced by multiple maps.
| 0 | REQUIRED | (SCENARIO Integer ID or multiple integer values in array [1, 2, 3]) | Scenario ID | |
| 1 | REQUIRED | (Boolean or multiple boolean values in array [true, false, true]) | Restart required |
| 204 | No Content |
curl 'https://engine.tygron.com/api/session/event/editorscenario/set_restart_testrun/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '[ 1, true ]'Curl example multi item POST
curl 'https://engine.tygron.com/api/session/event/editorscenario/set_restart_testrun/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '[ [ 1, 2, 3 ], [ true, false, true ] ]'JavaScript example POST
body: '[ 1, true ]'
fetch("https://engine.tygron.com/api/session/event/editorscenario/set_restart_testrun/", options)
