Api session event editor scenario set limit neighborhoods
Revision as of 12:23, 17 June 2026 by Frank@tygron.nl (talk | contribs)
API Endpoint: api/session/event/editorscenario/set_limit_neighborhoods/
Description: Set Limit Neighborhoods
0 REQUIRED (SCENARIO Integer ID) Scenarios
1 REQUIRED (NEIGHBORHOOD Integer ID or multiple integer values in array [1, 2, 3]) Neighborhoods
204 No Content
curl 'https://engine.tygron.com/api/session/event/editorscenario/set_limit_neighborhoods/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '[ 1, 1 ]'
Curl example multi item POST
curl 'https://engine.tygron.com/api/session/event/editorscenario/set_limit_neighborhoods/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '[ 1, [ 1, 2, 3 ] ]'
JavaScript example POST
 body: '[ 1, 1 ]'
fetch("https://engine.tygron.com/api/session/event/editorscenario/set_limit_neighborhoods/", options)
