Api session event editor parametric set alignment
API Endpoint: api/session/event/editorparametric/set_alignment/
Description: Set Alignment
| 0 | REQUIRED | (PARAMETRIC_DESIGN Integer ID or multiple integer values in array [1, 2, 3]) | Parametric Designs | |
| 1 | REQUIRED | (Alignment or multiple values in array [a, b, c]) | Alignment[] |
| 204 | No Content |
curl 'https://engine.tygron.com/api/session/event/editorparametric/set_alignment/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '[ 1, "ROAD" ]'Curl example multi item POST
curl 'https://engine.tygron.com/api/session/event/editorparametric/set_alignment/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '[ [ 1, 2, 3 ], [ "ROAD", "SPACED", "SPACED" ] ]'JavaScript example POST
body: '[ 1, "ROAD" ]'
fetch("https://engine.tygron.com/api/session/event/editorparametric/set_alignment/", options)
