Api session event editor overlay set overlay area
Revision as of 12:22, 17 June 2026 by Frank@tygron.nl (talk | contribs)
API Endpoint: api/session/event/editoroverlay/set_overlay_area/
Description: Add or remove specified Areas to or from a specified Areas Overlay. Unincluded Areas which are already related to the Overlay will remain related. Unincluded Areas which are not related to the Overlay will remain unrelated.
0 REQUIRED (OVERLAY Integer ID) Overlay ID (must relate to an Areas Overlay)
1 REQUIRED (AREA Integer ID or multiple integer values in array [1, 2, 3]) Array of Area IDs
2 REQUIRED (true, false) Should be added to the Overlay (false removes the Areas from the Overlay) true or false
204 No Content
curl 'https://engine.tygron.com/api/session/event/editoroverlay/set_overlay_area/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '[ 1, 1, true ]'
Curl example multi item POST
curl 'https://engine.tygron.com/api/session/event/editoroverlay/set_overlay_area/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '[ 1, [ 1, 2, 3 ], true ]'
JavaScript example POST
 body: '[ 1, 1, true ]'
fetch("https://engine.tygron.com/api/session/event/editoroverlay/set_overlay_area/", options)
