Api session event editor netload add address
Revision as of 12:22, 17 June 2026 by Frank@tygron.nl (talk | contribs)
API Endpoint: api/session/event/editornetload/add_address/
Description: Add Address
0 REQUIRED (NET_LOAD Integer ID or multiple integer values in array [1, 2, 3]) Net Loads
1 REQUIRED (ADDRESSE Integer ID or multiple integer values in array [1, 2, 3]) Addresses
204 No Content
curl 'https://engine.tygron.com/api/session/event/editornetload/add_address/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '[ 1, 1 ]'
Curl example multi item POST
curl 'https://engine.tygron.com/api/session/event/editornetload/add_address/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '[ [ 1, 2, 3 ], [ 1, 2, 3 ] ]'
JavaScript example POST
 body: '[ 1, 1 ]'
fetch("https://engine.tygron.com/api/session/event/editornetload/add_address/", options)
