Api session event editor geotiff remove
Revision as of 12:21, 17 June 2026 by Frank@tygron.nl (talk | contribs)
API Endpoint: api/session/event/editorgeotiff/remove/
Description: Remove existing GeoTIFF
0 REQUIRED (GEO_TIFF Integer ID or multiple integer values in array [1, 2, 3]) Geo Tiffs
204 No Content
curl 'https://engine.tygron.com/api/session/event/editorgeotiff/remove/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '1'
Curl example multi item POST
curl 'https://engine.tygron.com/api/session/event/editorgeotiff/remove/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '[ 1, 2, 3 ]'
JavaScript example POST
 body: '1'
fetch("https://engine.tygron.com/api/session/event/editorgeotiff/remove/", options)
