Api session event editor address set letter
Revision as of 12:20, 17 June 2026 by Frank@tygron.nl (talk | contribs)
API Endpoint: api/session/event/editoraddress/set_letter/
Description: Set Letter
0 REQUIRED (ADDRESSE Integer ID or multiple integer values in array [1, 2, 3]) Addresses
1 REQUIRED (String or multiple values in array ["a", "b", "c"]) String[]
204 No Content
curl 'https://engine.tygron.com/api/session/event/editoraddress/set_letter/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '[ 1, "Text 1" ]'
Curl example multi item POST
curl 'https://engine.tygron.com/api/session/event/editoraddress/set_letter/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '[ [ 1, 2, 3 ], [ "Text 1", "Text 2", "Text 3" ] ]'
JavaScript example POST
 body: '[ 1, "Text 1" ]'
fetch("https://engine.tygron.com/api/session/event/editoraddress/set_letter/", options)
