Api session event logic measurement point add
API Endpoint: api/session/event/logic/measurement_point_add/
Description: Add a PointMeasurement for an Overlay.
0 REQUIRED (OVERLAY Integer ID or multiple values in array [1, 2, 3]) Overlay IDs
1 REQUIRED (Point with crs: EPSG:3857) Point
2 REQUIRED (String) Name
3 REQUIRED (true, false) Save Measurement true or false
4 REQUIRED (true, false) Sum true or false
200 Integer (Measurement ID)
curl 'https://engine.tygron.com/api/session/event/logic/measurement_point_add/?crs=3857' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '
[ 1, {
 "type" : "Point",
 "coordinates" : [ 658668.1775159946, 6799319.238471406 ]
}, "Name", true, true ]
Curl example multi item POST
[ [ 1, 2, 3 ], {
 "type" : "Point",
 "coordinates" : [ 658757.085974044, 6799442.169723393 ]
JavaScript example POST
 body: '[ 1, { "type" : "Point", "coordinates" : [ 658668.1775159946, 6799319.238471406 ]}, "Name", true, true ]'
fetch("https://engine.tygron.com/api/session/event/logic/measurement_point_add/?crs=3857", options)
