Api session event editor weather set duration
API Endpoint: api/session/event/editorweather/set_duration/
Description: Set how long the specified Weather's visualization lasts when it is Triggered.
| 0 | REQUIRED | (WEATHER Integer ID) | Weather ID | |
| 1 | REQUIRED | (Floating point number) | Duration of visualization in seconds |
| 204 | No Content |
curl 'https://engine.tygron.com/api/session/event/editorweather/set_duration/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '[ 1, 96 ]'Curl example multi item POST
curl 'https://engine.tygron.com/api/session/event/editorweather/set_duration/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '[ 1, 17 ]'JavaScript example POST
body: '[ 1, 96 ]'
fetch("https://engine.tygron.com/api/session/event/editorweather/set_duration/", options)
