Api session event editor trigger add
Revision as of 12:07, 15 June 2026 by Frank@tygron.nl (talk | contribs)
API Endpoint: api/session/event/editortrigger/add/
Description: Add new Trigger
0 OPTIONAL (Timing or multiple values in array [a, b, c]) Timing[]
200 Integer[] (Integer array)
curl 'https://engine.tygron.com/api/session/event/editortrigger/add/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d ''
JavaScript example POST
 body: ''
fetch("https://engine.tygron.com/api/session/event/editortrigger/add/", options)
