Api session event editor sound set volume
API Endpoint: api/session/event/editorsound/set_volume/
Description: Set Volume
| 0 | REQUIRED | (SOUND Integer ID) | Sounds | |
| 1 | REQUIRED | (Floating point number) | Double |
| 204 | No Content |
curl 'https://engine.tygron.com/api/session/event/editorsound/set_volume/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '[ 1, 44 ]'Curl example multi item POST
curl 'https://engine.tygron.com/api/session/event/editorsound/set_volume/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '[ 1, 29 ]'JavaScript example POST
body: '[ 1, 44 ]'
fetch("https://engine.tygron.com/api/session/event/editorsound/set_volume/", options)
