Api session event editor setting set region
Revision as of 12:06, 15 June 2026 by Frank@tygron.nl (talk | contribs)
API Endpoint: api/session/event/editorsetting/set_region/
Description: Set Region
0 REQUIRED (Enumeration) Region AFRICA, ASIA, NORTH_AMERICA, NORTHWESTERN_EUROPE or OTHER
204 No Content
curl 'https://engine.tygron.com/api/session/event/editorsetting/set_region/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '"NORTH_AMERICA"'
JavaScript example POST
 body: '"NORTH_AMERICA"'
fetch("https://engine.tygron.com/api/session/event/editorsetting/set_region/", options)
