Api session event editor setting set rasterization
Revision as of 12:06, 15 June 2026 by Frank@tygron.nl (talk | contribs)
API Endpoint: api/session/event/editorsetting/set_rasterization/
Description: Set Rasterization
0 REQUIRED (Enumeration) RasterizationMethod CENTER, COMBINED or OUTLINE
204 No Content
curl 'https://engine.tygron.com/api/session/event/editorsetting/set_rasterization/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '"COMBINED"'
JavaScript example POST
 body: '"COMBINED"'
fetch("https://engine.tygron.com/api/session/event/editorsetting/set_rasterization/", options)
