Api session event editor setting get sun motion
Revision as of 12:06, 15 June 2026 by Frank@tygron.nl (talk | contribs)
API Endpoint: api/session/event/editorsetting/get_sun_motion/
Description: Get Sun Motion value for local Time in this Project (The Netherlands only)
0 REQUIRED (Integer number) Year
1 REQUIRED (Integer number) Month
2 REQUIRED (Integer number) Day
3 REQUIRED (Integer number) Hour
4 REQUIRED (Integer number) Minute
5 REQUIRED (Integer number) Second
200 Double (Sun Motion value)
curl 'https://engine.tygron.com/api/session/event/editorsetting/get_sun_motion/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '[ 2013, 8, 2, 12, 0, 0 ]'
JavaScript example POST
 body: '[ 2013, 8, 2, 12, 0, 0 ]'
fetch("https://engine.tygron.com/api/session/event/editorsetting/get_sun_motion/", options)
