Api session event editor setting get epoch time
API Endpoint: api/session/event/editorsetting/get_epoch_time/
Description: Get UTC Epoch Time (Milliseconds since 00:00:00 UTC on 1 January 1970) for local Time in this Project
| 0 | REQUIRED | (Integer number) | Year | |
| 1 | REQUIRED | (Integer number) | Month | |
| 2 | REQUIRED | (Integer number) | Day | |
| 3 | REQUIRED | (Integer number) | Hour | |
| 4 | REQUIRED | (Integer number) | Minute | |
| 5 | REQUIRED | (Integer number) | Second |
| 200 | Long (UTC Epoch Time (Milliseconds since 00:00:00 UTC on 1 January 1970)) |
curl 'https://engine.tygron.com/api/session/event/editorsetting/get_epoch_time/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '[ 2005, 9, 1, 0, 0, 0 ]'JavaScript example POST
body: '[ 2005, 9, 1, 0, 0, 0 ]'
fetch("https://engine.tygron.com/api/session/event/editorsetting/get_epoch_time/", options)
