Api session event editor scenario set limit neighborhoods
API Endpoint: api/session/event/editorscenario/set_limit_neighborhoods/
Description: Set Limit Neighborhoods
| 0 | REQUIRED | (SCENARIO Integer ID) | Scenarios | |
| 1 | REQUIRED | (NEIGHBORHOOD Integer ID or multiple values in array [1, 2, 3]) | Neighborhoods |
| 204 | No Content |
curl 'https://engine.tygron.com/api/session/event/editorscenario/set_limit_neighborhoods/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '[ 1, 1 ]'Curl example multi item POST
curl 'https://engine.tygron.com/api/session/event/editorscenario/set_limit_neighborhoods/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '[ 1, [ 1, 2, 3 ] ]'JavaScript example POST
body: '[ 1, 1 ]'
fetch("https://engine.tygron.com/api/session/event/editorscenario/set_limit_neighborhoods/", options)
