Api session event editor panel set text
Revision as of 12:05, 15 June 2026 by Frank@tygron.nl (talk | contribs)
API Endpoint: api/session/event/editorpanel/set_text/
Description: Set Text
0 REQUIRED (PANEL Integer ID) Panels
1 REQUIRED (String) String
200 String (String)
curl 'https://engine.tygron.com/api/session/event/editorpanel/set_text/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '[ 1, "Text" ]'
JavaScript example POST
 body: '[ 1, "Text" ]'
fetch("https://engine.tygron.com/api/session/event/editorpanel/set_text/", options)
