Api session event editor panel set layout xy
Revision as of 12:05, 15 June 2026 by Frank@tygron.nl (talk | contribs)
API Endpoint: api/session/event/editorpanel/set_layout_xy/
Description: Set Layout Xy
0 REQUIRED (PANEL Integer ID) Panels
1 REQUIRED (Floating point number) Double
2 REQUIRED (Floating point number) Double
204 No Content
curl 'https://engine.tygron.com/api/session/event/editorpanel/set_layout_xy/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '[ 1, 45, 65 ]'
Curl example multi item POST
curl 'https://engine.tygron.com/api/session/event/editorpanel/set_layout_xy/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '[ 1, 17, 18 ]'
JavaScript example POST
 body: '[ 1, 45, 65 ]'
fetch("https://engine.tygron.com/api/session/event/editorpanel/set_layout_xy/", options)
