Api session event editor panel add global
API Endpoint: api/session/event/editorpanel/add_global/
Description: Add Global
0 REQUIRED (PANEL Integer ID) Panels
1 REQUIRED (GLOBAL Integer ID or multiple values in array [1, 2, 3]) Globals
200 String (String)
curl 'https://engine.tygron.com/api/session/event/editorpanel/add_global/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '[ 1, 1 ]'
Curl example multi item POST
curl 'https://engine.tygron.com/api/session/event/editorpanel/add_global/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '[ 1, [ 1, 2, 3 ] ]'
JavaScript example POST
 body: '[ 1, 1 ]'
fetch("https://engine.tygron.com/api/session/event/editorpanel/add_global/", options)
