Api session event editor panel add
API Endpoint: api/session/event/editorpanel/add/
Description: Add new Panel
| 0 | REQUIRED | (Enumeration) | PanelType | EXCEL_PANEL, GLOBAL_PANEL, TEMPLATE_EXCEL_PANEL, TEMPLATE_TEXT_PANEL, TEXT_PANEL or WEB_PANEL |
| 200 | Integer (Integer) |
curl 'https://engine.tygron.com/api/session/event/editorpanel/add/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '"GLOBAL_PANEL"'JavaScript example POST
body: '"GLOBAL_PANEL"'
fetch("https://engine.tygron.com/api/session/event/editorpanel/add/", options)
