Api session event editor overlay set water weather
Revision as of 12:05, 15 June 2026 by Frank@tygron.nl (talk | contribs)
API Endpoint: api/session/event/editoroverlay/set_water_weather/
Description: Set a specified Weather to serve as input for a specified water Overlay.
0 REQUIRED (OVERLAY Integer ID) Water Overlay ID
1 REQUIRED (WEATHER Integer ID) Weather ID
204 No Content
curl 'https://engine.tygron.com/api/session/event/editoroverlay/set_water_weather/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '[ 1, 1 ]'
JavaScript example POST
 body: '[ 1, 1 ]'
fetch("https://engine.tygron.com/api/session/event/editoroverlay/set_water_weather/", options)
