Api session event editor overlay set key value
Revision as of 12:05, 15 June 2026 by Frank@tygron.nl (talk | contribs)
API Endpoint: api/session/event/editoroverlay/set_key_value/
Description: Change a key for a specified Overlay. The Overlay must be an Overlay which makes use of keys to read Attributes of geographical Items, as input for its calculation.
0 REQUIRED (OVERLAY Integer ID) Overlay ID (must relate to a Grid Overlay). Note: to change Attribute values use set_Attribute instead.
1 REQUIRED (String) Key name
2 REQUIRED (String) Attribute name to look for
204 No Content
curl 'https://engine.tygron.com/api/session/event/editoroverlay/set_key_value/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '[ 1, "Key name", "Attribute name to look for" ]'
JavaScript example POST
 body: '[ 1, "Key name", "Attribute name to look for" ]'
fetch("https://engine.tygron.com/api/session/event/editoroverlay/set_key_value/", options)
