Api session event editor overlay set heat model
Revision as of 12:05, 15 June 2026 by Frank@tygron.nl (talk | contribs)
API Endpoint: api/session/event/editoroverlay/set_heat_model/
Description: Set Heat Model
0 REQUIRED (OVERLAY Integer ID) Overlays
1 REQUIRED (Enumeration) HeatModel DPRA or UNESCO
204 No Content
curl 'https://engine.tygron.com/api/session/event/editoroverlay/set_heat_model/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '[ 1, "UNESCO" ]'
JavaScript example POST
 body: '[ 1, "UNESCO" ]'
fetch("https://engine.tygron.com/api/session/event/editoroverlay/set_heat_model/", options)
